Old 04-12-2009, 11:50 PM
nlfrnassimi nlfrnassimi is offline
max9 to cal3D xporting problem
I have installed Cal3D for 3DMax9 from website and installed it in the plugin folder of Max but still I can't see it in export option. Any one can help?
Old 04-13-2009, 12:46 AM
Why when I download and install the cal3D exporter exe file there are no .dll and other files in it?
Old 04-13-2009, 11:19 AM
Even though you need to select what you will export this particular plugin goes through "file --> export" and does not show up in "file --> export selected." Have you checked out "file --> export"?
Old 04-13-2009, 11:15 PM
yes I have tried that as well. The problem is that the exporter folder is empty. There are only text files in it. there are no .dll and other files to be copied in the plugin. Is there any other place that I can download the exporter?
Old 04-15-2009, 01:38 PM
So you're saying you downladed the Cal3D Exporter from our site. Then you ran the .exe file and that afterwards you don't see the Cal3D plug-in showing up in Max's plug-in folder?
Cal3D Stereo Bug? shivanangel Vizard 3 10-30-2008 07:38 AM
Incampatible CAL3D files luakt Vizard 4 09-14-2008 11:28 PM
cal3d exporter problem visnova Vizard 1 06-15-2007 03:02 PM
importing avatars with cal3d marcoleon Vizard 15 04-28-2006 04:48 PM
