Thread Tools Rating: Thread Rating: 4 votes, 4.00 average. Display Modes
Old 03-24-2009, 03:40 PM
just alex just alex is offline
smoothing a cubic bezier path
I've got an animation path that I've been having issues with. When I use a cubic bezier path, the curve will either swing too wide and leave the area I want the object to move in, or, when I add extra cp's to keep it on path, will jerk to reset it's facing rather than smoothly turn. The path is going to be way too long for just using a bezier and keeping it in the movement area.
Is there a decent way to smooth this out, or will I just have to live with the jerkiness?
Old 03-26-2009, 07:05 PM
Have you tried turning on autorotate for the animation path?
Old 04-01-2009, 05:00 PM
Yeah, I've got autorotate on, I'll post the code as soon as I get to my computer again
Old 04-01-2009, 10:09 PM
If you got the skills and the path is static, I'd stop right now and create the animation in 3ds Max.
I've spent way to much time tuning animation paths and they are never quite right.
Controlling the node's orientation with animation paths is the hardest. You might want to control the orientation with some other method. Perhaps you could have node 'lookat' another node that moves around too?
Old 04-02-2009, 11:40 AM
Here's the code.
The path is static, but I've never even looked at 3ds Max, so I wouldn't know what to do, though I might be able to pick it up with google fu.
I'll give it a go, but don't know how it'll work.
import math
import vizmat
import vizinfo
#Add the street and drop it a little bit to be below the avatars feet.
street = viz.add('objects/bspcity.bsp')
street.translate(0,-.2,0)
#Add car.
car = viz.add('mini.osgx')
car.setScale(.8,.8,.8)
car.translate(-23,0,-8.8)
path = viz.add(viz.ANIMATION_PATH)
positions = [[-23,0,-8.8],[-23,0,-8],[-34,0,-8],[-34,0,0],[-43,0,0],[-43,0,8],[-43,0,17]]
for x in range(0,len(positions)):
        cp = viz.add(viz.CONTROL_POINT)
        cp.setPosition(positions[x])
        path.add(cp,x+1)
path.constantspeed(viz.ON,1)
path.loop(viz.LOOP)
#computes cubic bezier
path.computetangents()
path.translatemode(viz.CUBIC_BEZIER)
path.setAutoRotate(viz.ON)
car.link(path)
def onkeydown(key):
  if key == ' ':
    path.play()
Old 04-07-2009, 01:43 AM
Would Google Sketchup be a possible substitute for 3ds Max?
Old 04-07-2009, 12:16 PM
Don't know if Google Sketchup will work. I'll try exporting an animation to VRML and Collada from Sketchup and testing in Vizard.
It would be nice to establish an art workflow that does not center around the expensive and complex 3ds Max.
Problems with interaction of vizact.turn and animation path Enlil Vizard 3 11-24-2008 05:23 PM
speed on animation path whj Vizard 8 11-17-2008 08:41 PM
Cubic Bezier Curve whj Vizard 0 11-10-2008 02:52 PM
another bezier animation problem masaki Vizard 1 01-24-2008 03:29 PM
Smooth transition from Linear to Bezier in animation masaki Vizard 2 01-13-2008 12:22 PM
