Old 01-05-2009, 03:38 AM
Saz Saz is offline
updating positional data
hope you all had a good Christmas and New Year. I am trying to get the joystick position to update on the screen, however instead of updating it merely writes over the previous value resulting in a huge jumbled mess. Would I need to define this process as a separate function?
file = open( 'speed_.txt' + str(subject),'w' )
#Open file in path
#file = open( path + 'speed.txt', 'w' )
def mytimer (num):
	joy_pos = str(joy.getPosition())
	#speed = joy_pos*[0.0,5.0,0.0]
	out = str(joy_pos + '\n')
	file.write(out)
	file.flush()
	print out
#Add text to the screen.
	speed = viz.addText(joy_pos, viz.SCREEN)
	speed.setPosition(.05, .9 )
	speed.fontSize (30)
	speed.message(str(joy_pos))
viz.callback( viz.TIMER_EVENT, mytimer )
viz.starttimer( 0, 0.25, viz.FOREVER )
Also as its the joystick position it comes up as an [x, y, z] co-ordinate system whereas I'm only really interested in the y-axis, is there a way around this? Its coded as follows:
def UpdateJoystick():
    #Get the joystick position
    x,y,z = joy.getPosition()
    #Get the twist of the joystick
    twist = joy.getTwist()
    #Move the viewpoint forward/backward based on y-axis value
    if abs(y) > 0.001: #Make sure value is above a certain threshold
        viz.MainView.move(0,0,-y*MOVE_SPEED,viz.BODY_ORI)
    #Move the viewpoint left/right based on x-axis value
    if abs(x) > 0.001: #Make sure value is above a certain threshold
        viz.MainView.move(x*0.1,0,0,viz.BODY_ORI)
    #Turn the viewpoint left/right based on twist value
    if abs(twist) > 0.001: #Make sure value is above a certain threshold
        viz.MainView.rotate(0,1,0,twist,viz.BODY_ORI,viz.RELATIVE_WORLD)
The y position would also need to be multiplied by a value in order to make sense but I'm guessing that's a simple math function?
Any help - as usual will be greatly appreciated!!!
Old 01-05-2009, 09:02 AM
for your first question you could just add a textbox to your screen instead of text
speed = viz.addTextbox(parent = viz.SCREEN)
add the textbox and set its position outside of your timer function and then change the message in the timer function.
I not sure if I understand your second question. If you only want to move in the y direction then you could just remove the code that updates the x position and turns the viewpoint from UpdateJoystick()
    if abs(y) > 0.2: #Make sure value is above a certain threshold
        viz.MainView.move(0,0,-y*0.1,viz.BODY_ORI)
you can multiply the y value by something else if you want it to update by a different amount.
Old 01-08-2009, 01:44 AM
Saz Saz is offline
Hi Jeff,
thanks for that, the joystick position is updating fine now once I took the textbox out of the timer loop. No, for the second part the code for the joystick position is working fine but what I am getting up on the screen at the moment is obviously the raw data of the joystick output - which is pretty meaningless to the observer, additionally it appears in the co ordinate system format of [0.0 0.0 0.0], wheareas I'm only really interested in the y co ordinate.
Therefore I'm trying to multiply the raw data of the joystick that's already acquired so that it appears in a meaningful context on the screen, say as mph or kph - which is what I'm having difficulty with
Old 01-08-2009, 10:00 AM
this should update the speed in just the y direction every time the timer function is called
#add textbox and set position on screen
text_speed = viz.addTextbox(parent = viz.SCREEN)
text_speed.setPosition(.15, .9 )
text_speed.fontSize (30)
old_posY = 0
def showSpeed():
	global old_posY
	current_pos = viz.MainView.getPosition()
	current_posY = current_pos[1]
	distance = abs(current_posY - old_posY)
	#get speed in meters/sec
	speed = distance/viz.elapsed()
	#get speed in km/hour
	speed = speed/1000*3600
	old_posY = current_posY
	#enter speed in textbox rounded to 1 digit after decimal
	text_speed.message(str(round(speed,1)) + 'km/hour')
vizact.ontimer(.25, showSpeed)
Old 01-09-2009, 03:59 AM
Saz Saz is offline
Hi Jeff,
thanks for that - unfortunately it doesn't update and I constantly get 0.0km/hr on the screen - even though its moving along the road. I tried inserting joy.getPosition() in place of viz.MainView.getPosition() to see whether the code in principle functions and whilst that does produce a change in km/hr when either accelerating or deccelerating, because this piece of code is looking at a difference between outputs - when the joystick is held constant; there is no difference and so 0.0km/hr appears on the screen
Old 01-09-2009, 09:17 AM
That code should give you 0 km/hour if you are not moving along the y-axis which is the height. I think you may be wanting to get the speed along the z-axis. If that's the case then just dind the difference in z coordinates rather than the y coordinates.
output data to screen Saz Vizard 1 12-19-2008 04:59 PM
Flagging the Data Elittdogg Vizard 5 04-11-2008 11:40 AM
Data Files betancourtb82 Vizard 6 05-04-2006 02:43 PM
Obtaining Positional Data Plasma Vizard 40 04-04-2006 11:31 AM
