Old 11-02-2008, 01:48 PM
whj whj is offline
speed on animation path
Hello Jeff,
Previously you helped me out with the problem that how to get the position of an object two seconds ahead. Thanks a lot. Here is the code with slight change on your code, in which a semi-transparent ball two seconds ahead of another ball on animation path. I have a question about their speed. Why the speed of balls changes a lot along the animation path although I used path.constantspeed(viz.ON,4). How can I get a smooth constant speed? Thanks.
viz.add('tut_ground.wrl')
ball = viz.add('ball.wrl')
ball.alpha(.5)
ball2 = viz.add('ball.wrl')
viz.MainView.move(0,3,-30)
path = viz.add(viz.ANIMATION_PATH)
path2 = viz.add(viz.ANIMATION_PATH)
positions = [ [2,0.15,50], [1,0.15,35], [0,0.15,25], [-4,0.15,15], [-10,0.15,8], [-25,0.15,0], [-15,0.15,-8], [-10,0.15,-10], [-6,0.15,-12], [-3,0.15,-15], [0,0.15,-18], [3,0.15,-16], [6,0.15,-8], [10,0.15,2], [15,0.15,0], [25,0.15,-12], [35,0.15,-12], [50,0.15,-12], [70,0.15,10], [90,0.15,30], [140,0.15,120] ]
for x in range(0,len(positions)):
cp = viz.add(viz.CONTROL_POINT)
cp.setPosition(positions[x])
path.add(cp,x+1)
path2.add(cp,x+1)
path2.constantspeed(viz.ON,4)
path.loop(viz.OFF)
path2.loop(viz.OFF)
path.translatemode(viz.BEZIER)
path2.translatemode(viz.BEZIER)
path.setAutoRotate(viz.ON)
path2.setAutoRotate(viz.ON)
#Link ball and ball2 to their paths
ball.link(path)
ball2.link(path2)
#start playing the first animation path immediately
path.play()
#start playing the second animation path after two seconds
vizact.ontimer2(2, 1, path2.play)
Old 11-03-2008, 07:38 PM
thanks for the post, we'll get back to you as soon as we can on this
Old 11-04-2008, 12:12 PM
the constantspeed method does not work with the bezier translation mode. If you use it with one of the other modes it should be fine.
Old 11-05-2008, 09:19 PM
whj whj is offline
Seems that computeTangents() mode doesn't work too. Then how can I smoothly move a object in a specified curve with constent speed?
Old 11-07-2008, 07:02 PM
Are you using
path.translatemode(viz.CUBIC_BEZIER)
path.computetangents()
I think this should work with constantspeed. Can you post an example with how you are using it.
Old 11-09-2008, 07:52 PM
whj whj is offline
Thanks Jeff. I didn't put path.translatemode(viz.CUBIC_BEZIER) in my code. Yes, cubic_bezier mode has constant speed.
BTW, it's not bad for me to specify all positions of a animation path using bezier translation mode, but it is really hard to find positions in cubic_bezier translation mode. Having a cubic-bezier curve, do you have any easy way to get its intermediate points?
whj
real time collision on animation path whj Vizard 10 10-06-2008 04:38 PM
Animation Path djdesmangles Vizard 2 06-11-2007 03:37 PM
Animation Path djdesmangles Vizard 0 06-06-2007 11:03 AM
Animation Tracks.... k_iwan Vizard 2 03-26-2007 05:52 PM
Jumpy animation Elizabeth S Vizard 1 11-08-2006 02:11 PM
