Old 10-14-2008, 07:24 PM
djdesmangles djdesmangles is offline
Question vizinfo + wiimote ?
Hello Wizards,
How can I interact with vizinfo when using wiimote ?
viz.FOREVER
Old 10-14-2008, 08:12 PM
You can use the following code to simulate a mouse press/release in windows:
import win32api
import win32con
#Simulate left mouse button pressed
win32api.mouse_event(win32con.MOUSEEVENTF_LEFTDOWN,0,0,0)
#Simulate left mouse button released
win32api.mouse_event(win32con.MOUSEEVENTF_LEFTUP,0,0,0)
Just call the corresponding code when the wiimote button is pressed/released and you should now be able to interact with all GUI elements and other applications that are running on your system.
Old 10-14-2008, 08:22 PM
Forgot to mention one important thing. You will also need to simulate mouse movement using the following code:
win32api.mouse_event(win32con.MOUSEEVENTF_ABSOLUTE,int(65535*x),int(65535*(1.0-y)),0)
The x,y values represent the normalized screen coordinates, which should be equal to the IR position of the wiimote, assuming you are in fullscreen mode.
Old 10-21-2008, 03:21 PM
Unhappy ...not working
Yo !! Wizards !!
I simply cannot make that thing work... Are you sure it'll work inside a OpenGL rendered Window ?
viz.FOREVER !!
D.
Old 10-21-2008, 03:44 PM
Some piece of code...
Here's some codes:
def onTimer(num):
	global wm_pX
	global wm_pY
	global mess1
	global mess2
	global mess3
	global crosshair
	if num == 0:
		wm_pX = wiimote.posIR[0]
		wm_pY = wiimote.posIR[1]
		crosshair.setPosition(wm_pX, wm_pY)
		win32api.mouse_event(win32con.MOUSEEVENTF_ABSOLUTE, int(wm_pX * 1680), int((1-wm_pY) * 1050), 0)
	if num == 1:
		if wiimote.state == 16:
			win32api.mouse_event(win32con.MOUSEEVENTF_LEFTDOWN, int(wm_pX * 1680), int((1-wm_pY) * 1050), 0)
			time.sleep(0.05)
Old 10-22-2008, 08:33 AM
Source Code
Hello Wizards,
It's me again... This problem is driving me loco... I've attached the source code to the message...
viz.FOREVER !!!
D.
Sending sound to Wiimote ? djdesmangles Vizard 1 07-31-2008 11:26 AM
wiimote and sensor bar masaki Vizard 1 03-06-2008 03:07 PM
"Vizard Lite" graphic obscuring vizinfo pups halley Vizard 0 05-30-2006 10:07 AM
vizinfo in HMD mode enkeli Vizard 8 03-01-2006 03:47 PM
vizinfo vadrian Vizard 1 11-05-2004 02:40 PM
