Thread Tools Rating: Thread Rating: 5 votes, 5.00 average. Display Modes
Old 01-04-2008, 11:41 PM
Atul Thakur Atul Thakur is offline
Wanda button events on flock of birds
I am able to track the positions using my FOB (1 bird).
There are three buttons and a joystick control on the wanda.
Are there any functions in Vizard to use the events generated by these buttons and joysticks? I saw the documentation of flockofbirds plugin but couldn't find any. If not, do i need to write my own plugin <where to get information about writing my own plugin>?
Kindly point me to some sample codes if it exists.
Thank you,
sincerely,
-Atul
Old 01-06-2008, 08:12 AM
mspusch mspusch is offline
Hi Atul,
I believe there have been similar discussions before, please have a look at
http://www.worldviz.com/forum/showthread.php?t=678
and see if that helps.
Have fun!
Old 01-06-2008, 05:50 PM
Thank you for the reply.
I followed the discussion you indicated. My problem is that my joystick is not working neither the wanda buttons. I can only retrieve the orientation of the wanda. Is there a method to access the joystick or wanda button action?
regards,
-Atul
Old 01-07-2008, 10:36 AM
According to Ascension, the Wanda is a standard plug-n-play joystick device. This means you should be able to use our joystick module to access the joystick/button data. There are a few example scripts that come with Vizard showing how to use the joystick module and they are also included in the documentation.
Old 01-08-2008, 02:42 PM
Hi:
I tried using the joystick code into my fob code as follows
PHP Code:
import viz
import sid
viz
.go()
BAUD_FOB = 38400
PORT_FOB
= 1
sensor
= viz.add('flockofbirds.dls')
viz.tracker()
pos = [0,0,0]
room = viz.add("room.wrl")
room.translate(0,0,3)
table = viz.add("table.wrl")
table.translate(0,0,3)
def onkeydown(key):
    if
key == 'a':
pos = sensor.get()
        print
pos
viz
.callback(viz.KEYDOWN_EVENT,onkeydown)
##to see whether joystick works o not
def joydown(button):
    print
"Joystick worked!!"
Joystick action is not printing anything
Moreover, I don't have any idea, how to use the buttons on the wanda.
Also, for the information, when I run winbird.exe <Ascension's program> The position and orientations are registered properly but joystick or buttons don't do anything.
I am not sure if the joystick and buttons are working alright or not. Please let me know if there is any method to test that.
Thank you,
-Atul
Old 01-08-2008, 03:34 PM
If you can't get the joystick/buttons working with Ascension's software then you will need to contact them for support.
Flock of Birds recognized, but no data sent sjroorda Vizard 9 03-01-2016 09:48 PM
Flock of Birds Atul Thakur Vizard 6 12-20-2007 01:18 PM
Flock of Birds question (again) Elittdogg Vizard 24 12-04-2007 10:37 AM
Flock of Birds Elittdogg Vizard 9 10-02-2007 02:53 PM
Flock of birds extended range problem theuberk Vizard 4 07-30-2007 10:31 AM
