Old 09-26-2007, 10:34 PM
ajmurray ajmurray is offline
quad-buffered stereo on cluster
hi all,
i'm having the same problem as described in this thread:
http://www.worldviz.com/forum/showth...ghlight=stereo
my setup is exactly the same, with 3 clients and 1 master system. the master doesn't need to run any kind of stereo, but the three clients do.
anaglyphic works fine however quad buffered doesn't. hardware is no problem as i've tested quad buffered on each client individually and it works fine.
was this problem not fixed with 3.0? is there a workaround for it?
cheers
-ajm
Old 09-27-2007, 12:02 PM
The current workaround is to add the following line to the vizcore.cfg file of all the client computers:
viz.quadbuffer = 1
This will not be necessary in the next release.
