Old 09-06-2016, 01:49 PM
About vizproximity
When I add a sensor to a object, there will be a sensor like a frame outside the object.
Is there a method to get rid of the green frame like setting it to transparent or setting it only shows up when the mouse enter the sensor?
Old 09-06-2016, 03:29 PM
Vaquero Vaquero is offline
You can do something like:
manager.setDebug(viz.OFF)
debugEventHandle = vizact.onkeydown('1',manager.setDebug,viz.TOGGLE)
That way you can turn the debug shapes on/off with a key press, in this example '1'.
Old 09-08-2016, 08:47 AM
thanks it works
Old 09-06-2016, 10:31 PM
rajnishv rajnishv is offline
Smile
Hi haohaoxuexi1
You can also use the Proximity Events when the target(MainView or Grabbber or any object) enters the proximity ,the Outer box Debug can be set to OFF and when the target leaves the proximity area the debug can bet set to ON.
def EnterProximity(e):
if e.sensor==sensor1:
if e.sensor==sensor2:
#and so on
def ExitProximity(e):
manager.setDebug(viz.ON)
#-----Registering sensors for proximity enter and exit evenst--------#
manager.onEnter(None,EnterProximity)
manager.onExit(None,ExitProximity)
Thanx & reagrds
Mr.Rajnish Vishwakarma
Software Developer for Mobile,AR,VR
Old 09-08-2016, 08:48 AM
Originally Posted by rajnishv View Post
Hi haohaoxuexi1
#and so on
Thanx & reagrds
thanks it works
vizproximity hint - debug 2D areas related to a source only after adding a target! fordprefect Vizard 1 12-15-2014 12:37 PM
wait for vizproximity and waitKeyDown in task krimble Vizard 2 08-14-2013 03:14 AM
Vizproximity questions. nabrahamson Vizard 3 04-04-2012 04:59 PM
