Old 04-05-2013, 02:06 PM
Zhi Zhi is offline
Does Vizard 4 support PROPixx projector
Hi guys,
Our lab is planning to purchase a PROPixx projector (http://www.vpixx.com/products/visual...s/propixx.html). The projector takes a single dual-link DVI input. We want to use it with Vizard 4 and generate 3D stimuli for our experiment. Here are two possible ways that they claimed on how to generate left/right-eye images:
1. You could drive your graphics board at 1920x1080 @ 120Hz, and project 60Hz per eye.
2. You could also project the incoming red component as a grayscale image to 1 eye, and the green component as a grayscale image to the other eye, resulting in 120Hz per eye.
We intend to use the first way they suggested. But we don't know how to alternatively (by frame) feed the left/right-eye images to the single Dual link DVI input with Vizard. Has anyone used the PROPixx projector with Vizard 4 and know how to generate left/right-eye images in alternative frames.
Thanks in advance.
Zhi
Old 04-05-2013, 02:12 PM
It sounds like you would need to use the viz.QUAD_BUFFER stereo mode. This would require a graphics card that supports quad buffered stereo (e.g. nVidia Quadro series)
Old 04-05-2013, 09:53 PM
goro goro is offline
Fzrshizzo, Can you please suggest entry level cost effective quad buffered stereo nVidia graphic card?
Old 04-06-2013, 05:10 AM
mspusch mspusch is offline
for serious work, but not in the extreme high end, we would recommend the
nVidia quadro 4000
series cards.
I reallize all professional quadro cards are not exactly on the cheap side ...
Matthias
Old 04-08-2013, 05:31 PM
Zhi Zhi is offline
Thank you for your suggestions. Does it mean that to use the viz.QUAD_BUFFER stereo mode, we need buy a quad buffered stereo graphic card?
Old 04-09-2013, 01:25 PM
Yes, we recommend a card from the nVidia Quadro series.
Ideas for Vizard support in OSGExp Joran Vizard 8 08-01-2006 09:39 AM
