Old 05-11-2009, 04:04 AM
nasr nasr is offline
how to write the interface code
hello all,
my university got a virtual reality suite which consists of a projector, a transluscent screen, amx controller, intersense 900 inertial ultra sonic motion tracking system, wand and head trackers. i will import a catia based 3d model in vizard. could some body please tell me how can i navigate with the wand and head tracker in my application. how to write the interface code? are there any ebooks available on the vizard site?
thankyou...
with regards
Nasr
Old 05-11-2009, 02:03 PM
To support multiple hardware interfaces, like a keyboard+mouse test mode and production VR tracker mode, you want to separate the "application logic" from the hardware interface code. Their are a few ways you can organize the code to do this. I would use object oriented classes.
Say the user interacts with your Catia model with some 3D cursor thing. That is application logic. I'ed create a Cursor class that holds all the application level information and behavior for this 3D cursor: 3D position, appearance, methods for selecting and moving the Catia model.
I'd create another class called CursorControllerKeyboard that has a pointer to the Cursor class. This guy will respond to keyboard events and manipulate the Cursor appropratly. Another class called CursorControllerWand could manipulate the Cursor in response to input from the Intersense Wand device.
Let the Cursor classes constructor choose which controler to create based on some configuration varable. Here's some code:
IS_VR_HARDWARE_CONNECTED = False
class Cursor:
	def __init__(self):
		#Application level stuff
		self.root = viz.addGroup() #3d position
		self.model = viz.add('arrow.wrl', parent=self.root)
		if IS_VR_HARDWARE_CONNECTED:
			self.CursorControllerWand(self) #pass pointer to self
			self.CursorControllerKeyboard(self) #pass pointer to self
	def grabModel(self):
		#application level stuff
		self.model.color(viz.GREEN)
	class CursorControllerKeyboard: #sub-class of Cursor, only Cursor can use me
		def __init__(self, appCursor):
			self.appCursor = appCursor
			vizact.onkeydown(viz.KEY_UP, self.appCursor.root.setPosition, [0,0,1], viz.REL_LOCAL)
			vizact.onkeydown(' ', self.appCursor.grabModel)
	class CursorControllerWand: #sub-class of Cursor, only Cursor can use me
			#do Vr hardware callbacks
if __name__ == '__main__':
	Cursor()
Paul Elliott
WorldViz LLC
Old 05-12-2009, 02:26 AM
how to move the other part
def toggleLink():
	global link
	if link:
		#If link exits, stop grabbing
		link.remove()
		link = None
	elif vizmat.Distance(hand.getPosition(), ball.getPosition()) < .5:
		link = viz.grab( hand, ball )
vizact.onpick(ball,toggleLink)
with this code i am able to one component using the marker. i have included one more component.. when i am trying to pick the other component the first component is also moving how to disable the link between the market and first component?
Old 05-12-2009, 11:15 AM
For your elif block:
if link is not none: remove link
Paul Elliott
WorldViz LLC
Old 05-12-2009, 11:22 AM
Better. Replace elif with if.
def toggleLink():
	global link
	if link:
		link.remove()
		link = None
Paul Elliott
WorldViz LLC
Old 05-13-2009, 12:09 AM
paul thank you very much for your reply.this is my full program
viz.MainView.setPosition(0,1.5,-4)
import viztracker
tracker = viztracker.MousePos()
myroom=viz.add('room.wrl')
#Add the object that will do the grabbing and link it to the tracker
hand = viz.add('marker.wrl')
viz.link(tracker, hand)
#turn off mouse navigation
viz.mouse(viz.OFF)
#Add the object that the marker will grab
ball = viz.add( 'ball.wrl' )
ball.translate( 0.5, 1.5, 3 )
table=viz.add('table.wrl')
link = None
#Grab or let go of the ball
def toggleLink():
	global link
	if link:
		link.remove()
		link = None
now i want to move the ball and the table seperately. now could you please tell me how to make the changes.
Old 05-13-2009, 01:37 PM
Because of the grab link, rotating the hand will rotate the object. Use whatever keyboard/mouse keys you want.
Paul Elliott
WorldViz LLC
Old 05-14-2009, 12:49 PM
paul thankyou very much for your suggestions...could you tell the code for rotating the ball using the mouse...i dont have any idea how to do it...just give me the clue...
thankyou..
Old 05-15-2009, 11:16 AM
hello paul...i tried rotating the object using the keyboard..by assigning keys for each axis....but i want to do this using mouse in order to reduce the number of lines of code...could u please tell me the function for that. how it could be done? i wil be waiting for ur reply..thankyou...
Old 05-15-2009, 11:37 AM
How about rotating an object when you hold down the right mouse button. You could use Jerry's code from this post to rotate the object after it is selected: http://forum.worldviz.com/showthread.php?t=2022
Paul Elliott
WorldViz LLC
Old 05-15-2009, 11:46 AM
def toggleLink():
	global link
	if link:
		link.remove()
		link = None
	if vizmat.Distance(hand.getPosition(),crank.getPosition()) < .5:
		link=viz.grab ( hand, crank)
vizact.onmousedown(' ' ,toggleLink())
i wrote this code for grabbing the first object and then releasing it and then trying to hold the second object..but its not working...paul can u tell me where is the problem?
Old 05-15-2009, 12:08 PM
The vizact.onmousedown(' ' ,toggleLink()) needs a mouse button argument. Check docs on this.
Otherwise I don't see whats wrong. Throw some print statements around to see where the code is going or not going.
You also have the possibility of creating two links and loosing your handle to the first link. To fix create a list of grabable objects and use a "for in" loop to check if the hand should grab. If you grab, end the loop with a "break" statement.
Paul Elliott
WorldViz LLC
Old 05-15-2009, 12:28 PM
def toggleLink():
	global link
	if link:
		link.remove()
		link = None
vizact.onpick(viz.MOUSEBUTTON_RIGHT ,toggleLink)
paul im trying with this mouse event..but still not able to select any one object at this time...
Old 05-15-2009, 12:32 PM
sorry i tried with this code also...but not working
def toggleLink():
	global link
	if link:
		link.remove()
		link = None
vizact.onmousedown(viz.MOUSEBUTTON_RIGHT ,toggleLink)
Old 05-19-2009, 04:21 AM
how to achieve the stereoscopic vision
how to enable the stereoscopic vision in a simple vizard application....
Any ideas on linking chess 3ds file with source code? djones1010 Vizard 1 04-24-2009 09:56 PM
Trying to integrate Source Code with Vizard djones1010 Vizard 1 03-10-2009 02:58 PM
Vizard Tip of the Month: Use Tasks to Simplify your Code Gladsomebeast Vizard 5 05-02-2008 04:30 PM
3D Music Interface Psirus Vizard 3 02-26-2008 11:48 AM
Vizard Crashes: causes are hard to determine, possible problem with the viz code vr_boyko Vizard 1 01-07-2005 10:52 AM
