Old 03-20-2009, 01:40 PM
Uttama_vizard Uttama_vizard is offline
Avatar speaking problem
My application requires interacting with an avatar (speaking) while wearing an eye tracking. What I want is that if my gaze goes towards the avatar, then the character should speak, but, when my gaze goes away from the avatar, the avatar should stop speaking or say something else.
But, the problem I am facing is that I am not being able to interrupt the avatar's previous action (before its scheduled completion).
I am using:
sound = vizact.speak("words.wav", scale= 0.007, sync=True)
character1.addAction(sound, pool=pool_number); pool_number = pool_number+1;
Then when I am using character1.clearActions(), it seems to me that I am not being able to interrupt the avatar's speech before its sceduled end point.
Any suggestion would be really appreciated.
Uttama
Old 03-20-2009, 08:04 PM
What you gotta do is write your own speak action.
Actions are defined in Python code, the vizact module actualy. There is an user defined action example in the Vizard help. Check that doc out, then open up vizact.py and examine the speak action. Copy the speak code into your own action module and modify it to stop the sound when the end action function is called.
Paul Elliott
WorldViz LLC
Old 03-21-2009, 03:50 PM
Avatar Speaking Problem
As per your reply, I was actually trying to update the speak function in this way:
def speak(filename, scale=1.0, morph='mouth_open', threshold = 0, sync = False):
import vizwave
#Get wave data
fname = viz.res.getFullPath(filename) or filename
avnumbers,length = vizwave.getsamples(fname,400,5)
if len(avnumbers) > 0 and threshold < 0:
# calculate default threshold, otherwise provided threshold is used
sum = 0
for value in avnumbers:
sum = sum + value
threshold = sum / len(avnumbers) # average value of the array
bla = viz.ActionData()
bla.data = [avnumbers,length,morph,fname,scale,threshold,sync]
bla.actionclass = VizSpeakAction
return bla
def end(self,object):
if not self.finished():
if self.audio:
self.audio.stop()
self.audio.remove()
if self.bone:
self.bone.unlock()
elif self.morphObj:
self.morphObj.morph(self.morph,0)
viz.ActionClass.end(self,object)
def pause(self,state):
viz.ActionClass.pause(self,state)
if self.audio:
if state:
self.audio.pause()
self.audio.play()
But, it is not working properly. Actually, I feel I am not updating the speak action properly.
If you can help me in this updating of the speak function (that is stopping and pausing it as required), it would be really great.
Thanks in advance for your valuable time.
Uttama
Old 03-22-2009, 10:16 AM
Dear Mr.Uttama,
Just checked out the speak code in vizact and it looks like if you call vizact.speak with undocumented keyword 'sync' set to True then the audio stops when the action is canceled.
vizact.speak('jfk.wav', sync=True)
The 'sync' code keeps the mouth flapping and audio syncronized on long speak files. To do this, the code creates an audio object, rather than just calling viz.playsound, the default behevor you were seeing.
Farshizo, perhaps the next release should include viz.playsound(self.filename, viz.STOP) in the end method of VizSpeakAction?
Paul Elliott
WorldViz LLC
Old 03-23-2009, 12:29 PM
Avatar_speaking problem
Thank you so much for your time. Yes, I have also noted that without the sync set to true, the flapping of the avatar's lips with the sound file is not synchronized.
When can we expect the next release with this feature built in? It would be really helpful.
Uttama
Collision of an avatar with a quad Frank Verberne Vizard 8 06-04-2008 10:44 AM
Problem with letting an avatar face towards another avatar ghazanfar Vizard 2 03-21-2007 03:30 AM
Avatars in an array and link/unlink betancourtb82 Vizard 7 09-05-2006 05:06 PM
avatars speaking problem shai Vizard 2 11-17-2004 11:13 AM
