Old 07-04-2019, 12:51 PM
hannahapz hannahapz is offline
Timer and Visibility Issue
This is my goal:
1) A appears for 500 msec (this is the cue)
2) Inter-stimulus interval of 650 msec (ISI)
3) B appears for 500 msec (this is the main stimulus) and then disappears
Right now, I have 1) and 2) successfully coded, but B doesn't want to go away (it stays on-screen).
When I try to time B to become invisible, it never appears in the first place. Below is the code representing this situation. The main_function calls the Timer/Visibility functions. A and B represent the cue and stimulus object nodes, respectively.
def cueshow():
    cue.setPosition([x,y,z])
    cue.visible(viz.ON) #make target visible
    starttimer(0, 0.5) # cue is visible for 500 msec
    callback(viz.TIMER_EVENT,CueTimer) #then make cue invisible
def CueTimer(num):
    cue.visible(viz.OFF)
def stimshow():
    starttimer(0, 1.15) # wait 1.15 seconds (500 msec of when cue first appears + 650 msec ISI)
    callback(viz.TIMER_EVENT,StimTimer) # then make target visible
def StimTimer(num):
    node.setPosition([x,y,z])
    node.visible(viz.ON)
def stimhide():
    starttimer(1, 1.65) # wait 1.65 seconds until turning stimulus off
    callback(viz.TIMER_EVENT,StimHideTimer)
def StimHideTimer(num):
    node.visible(viz.OFF)
def main_function():
    A.cueshow()
    B.stimshow()
    B.stimhide()
Old 07-04-2019, 01:11 PM
One thing I should probably mention is that the main_function runs on every frame.
Old 07-05-2019, 12:14 AM
Try using a task function to control the program flow. For example:
Press spacebar to start
import vizinfo
import viztask
vizinfo.InfoPanel()
cue = viz.addChild('soccerball.osgb',pos=[0,1.8,2])
stim = viz.addChild('basketball.osgb',pos=[0,1.8,2])
stim.visible(viz.OFF)
def experimentTask():
	yield viztask.waitKeyDown(' ')
	cue.visible(viz.ON)
	yield viztask.waitTime(0.5)
	yield viztask.waitTime(0.65)
	stim.visible(viz.ON)
viztask.schedule( experimentTask() )
