Old 12-05-2018, 06:36 AM
tokola tokola is offline
Vizard 5: ** ERROR: Failed to load model
all of the sudden my modules do not recognize the relative path where I've stored my models. It's just one level down from the .py files but the files are not found by the commands (e.g., viz.addChild('models/model.ive'))
They only worked when I moved them in the Vizard>Resources folder but, of course, this is not a permanent solution.
Any ideas?
Old 12-05-2018, 08:51 PM
Are you able to reproduce this issue with a simple script?
model = viz.addChild('model/model.ive')
Are you able to open up the model file in Inspector?
Regarding .FBX exported model with animation not played in Vizard rajnishv Vizard 5 01-06-2017 02:00 PM
using sketchup model in vizard Oshimeier Vizard 1 02-17-2015 09:59 AM
Vizard .exe file doesn't load (Vizard 3) Saule Vizard 4 02-05-2014 06:01 AM
