Old 12-25-2017, 12:49 PM
fivel_lab fivel_lab is offline
vizconnect getMovementScale
Hello
We are trying to use vizconnect's <WrappedAvatar>.setMovementScale() but we don't see any changes in the behavior of the avatar when it is moving. The vizconnect configuration uses Microsoft Kinect/FAAST as a tracker.
I have confirmed that I can change the movement scale VALUES:
SCALE = .1
myAvatar = vizconnect.getAvatar()
print 'Original movement scale: ' , myAvatar.getMovementScale()
myAvatar.setMovementScale([SCALE , SCALE , SCALE ])
print 'New movement scale: ' , myAvatar.getMovementScale()
but like I said above, this does not appear to do anything to the movement of the avatar. I've used values of SCALE as low as 1e-23 and as high as 10000, but the rendered movement seems identical no matter what the value is!
What does this method do, exactly? Am I missing some critical step to get it to work? Thank you!
Any guidance would be greatly appreciated!
3D monitor display with Vizconnect rdkirkden Vizard 2 09-14-2017 02:17 AM
Regarding changing &using multiple tools at same time through vizconnect rajnishv Vizard 7 09-08-2016 04:48 AM
Zspace display in Vizconnect JB_HP_Viz Vizard 5 06-05-2015 03:28 PM
Switching between input devices setup in vizconnect and not using vizconnect JB_HP_Viz Vizard 1 01-20-2015 05:19 AM
Vizconnect Save As Dialog Jeff Vizard 0 05-01-2014 09:45 AM
