Old 03-20-2017, 09:26 AM
arshbot arshbot is offline
Model moves with Vizconnect
import vizconnect
# start the vizconnect session stored in the given directory
vizconnect.go("HTC_Config.py")
vizconnect.getTransport('main_transport')
oriMode = vizconnect.VIEWPOINT_MATCH_DISPLAY
posMode = vizconnect.VIEWPOINT_MATCH_FEET
current_pos=[-53.32425, -0.78460, -29.09994]
vp=vizconnect.addViewpoint( pos=current_pos,
posMode=posMode,
oriMode=oriMode,
constant=False,
mylight = viz.addSpotLight(spread=180, pos=(10, 100, 0))
mylight.intensity(100)
vp.add(vizconnect.getDisplay())
vizconnect.resetViewpoints()
# add an environment
candela = viz.add('foo.osgb')
viz.add('tut_ground.wrl')
view = viz.MainView
viz.clearcolor(viz.SKYBLUE)
SPEED = 12.0
MODE = viz.SPEED
transport = vizconnect.getTransport('main_transport')
viz.link(transport.getNode3d(), candela)
viz.MainView.move([0,0,-6])
def gotoViewPointAmeniteis(pos):
........global vp
........action = vizact.goto(pos,SPEED,MODE,pivot=vizconnect.getVie wpointDict())
........vizconnect.getTransport('main_transport'). getNode3d().runAction(action)
def move():
........if viz.key.isDown(viz.KEY_UP):
................print 'key is up'
................#view.move([0,0,MOVE_SPEED*viz.elapsed()],viz.BODY_ORI
................global current_pos
................current_pos[2] += 5
................gotoViewPointAmeniteis(current_pos )
........elif viz.key.isDown(viz.KEY_DOWN):
................print 'key is down'
................#view.move([0,0,-MOVE_SPEED*viz.elapsed()],viz.BODY_ORI
................current_pos[2] -= 5
vizact.ontimer(0, move)
The script I have attempts to move the user throughout the model, however what I have learned is happening is that the model that is the main environment is moving with the user, instead of being stationary. I learned this because of the spotlight. The spotlight is stationary while the rest of the model moves. How can I lock the model in place so the user can move about? I am also using an HTC Vive and would like to use the wands to move, but for now I am content with using the keyboard since it's simpler.
movement, vive, vizconnect
Switching between input devices setup in vizconnect and not using vizconnect JB_HP_Viz Vizard 1 01-20-2015 06:19 AM
Vizconnect Save As Dialog Jeff Vizard 0 05-01-2014 10:45 AM
Accesing different parts of model pankaj bansal Vizard 1 12-30-2012 11:10 PM
3ds Exported .IVE Model mirrors movement of Mainview Felix Vizard 9 05-18-2012 10:17 AM
Change model alpha and memory leak hosier Vizard 2 06-25-2009 11:55 AM
