Old 09-15-2016, 12:53 PM
flatland flatland is offline
orthographic projection question
Hi everyone,
I'm fairly new to Vizard and am working with orthographic projection. I have a basic question. In the program below, the application window has an aspect ratio of 1, as does the width and height of the 100x100 region between the left/right/top/bottom clipping planes in the orthographic projection setup. But when I run the program, the 90x90 vertical quad centered at (0,0,0) doesn't appear centered vertically in the application window. It is slightly displaced in the downward direction, and I don't understand why. (This is causing me problems when I try to connect mouse coordinates in the application window with objects in the scene.) Anyone have an idea why this is happening?
Robin
# set application window size
viz.window.setSize( 700, 700 )
# set mainWindow
viz.MainWindow.ortho(-50,50,-50,50,-1,1)
viz.MainWindow.clearcolor( viz.BLACK )
viz.startLayer(viz.QUADS)
viz.vertexColor(1,0,0)
viz.vertex(-45, 45, 0)
viz.vertex(-45,-45, 0)
viz.vertex( 45,-45, 0)
viz.vertex( 45, 45, 0)
viz.endLayer()
Different projection matrix per viewpoint dcnieho Vizard 6 07-08-2016 05:06 AM
Regarding 3 Walled Projection queries rajnishv Precision Position Tracker (PPT) 0 04-12-2016 06:19 AM
Projection Matrix (onto oblique near plane) andrewjworz Vizard 1 07-13-2012 09:10 AM
Intermittent orthographic stereo projection problems AySz88 Vizard 10 02-17-2012 12:50 PM
orthographic projection in a head-tracked cave environment michaelrepucci Vizard 5 12-14-2011 10:29 AM
