Thread Tools Rating: Thread Rating: 6 votes, 5.00 average. Display Modes
Old 05-04-2006, 09:29 AM
wolbers wolbers is offline
perspective rendering
is it possible to automatically scale the size of on-the-fly objects to convey depth impression? I have created a ground plane consisting of points, but Vizard applies the same pointsize to each point, independent of the distance to the observer.
Best,
Thomas
Old 05-04-2006, 10:30 AM
If you want the points to be scaled by distance then try using a billboarded quad instead of On-The-Fly objects. Here is some code:
quad = viz.add(viz.TEXQUAD)
quad.billboard()
quad.scale(0.2,0.2,0.2) #Need to scale it only once
quad.translate(x,y,z) #Position the quad
Now perspective rendering will work correctly on the points
If you plan on using a lot of points then this might not be the most effiecient solution. If this is the case, then there is an alternative solution which requires a plugin. However, try this method first and let me know if it is sufficient.
Old 05-04-2006, 11:19 AM
Thanks for your suggestion. Your solution worked fine, however, given that I need 2000-3000 points, the animation was somewhat slowed down. Do you think the plugin could handle that?
Old 05-04-2006, 11:24 AM
Not sure, but it will definitely handle better than using 2000 billboarded quads. Are the position of the points static or dynamic. If they are static then you shouldn't need a plugin.
Old 05-04-2006, 11:39 AM
They are all dynamic - from frame to frame, some points will be redrawn at random locations, whereas others will be slightly displaced along the z-axis.
Old 05-04-2006, 12:50 PM
I've attached a zip file which contains a plugin and sample script on how to use it. The points should have some form of perspective rendering on them.
