Old 05-16-2016, 07:25 AM
jelly jelly is offline
Question Scheduling action at different timings using time.time()
Hello!
I am trying to schedule an action (a beep sound) in Vizard. However, I want the beep to happen at certain timings since onset of the trial.
What I have so far gives me (for example, after running it once) a list of times "times: [ 1.89229142 5.2610474 9.86058804 11.43137033 13.87078666]" and is playing the beep at what seems to be varying intervals and prints out the elements of the above mentioned list. It's just that it's not actually using these elements as seconds/timings at which to play.
My question is: How do I make Python know that these are not just numbers, but timings since onset of the function/trial? Probably I am supposed to use time.time() somewhere, but I am just not sure about the logic of how to get there.
import time
import numpy as np
import viztask
### Start Vizard ###
### Cue sound ###
cue = viz.addAudio('cues\dong.wav')
cueDuration = cue.getDuration()
### Timings ###
def uniform_min_range(a, b, n, min_dist):
    while True:
        times = np.random.uniform(a, b, size=n)
        np.sort(times)
        if np.all(np.diff(times) >= min_dist):
            return times
def timings():
    global times
    times = uniform_min_range(0, 20, 5, 1.0)
    print "times: ", times
def main():
    global times
    timesIndex =0
    for x in range(len(times)):
        cuetime = times[timesIndex]
        cue.play()
        print 'cue'
        print cuetime
        yield viztask.waitTime(cueDuration + cuetime)
        cue.stop()
        timesIndex = timesIndex + 1
timings_short()
viztask.schedule(main())
time, timing
Walking action of avatars SivaKartheek Vizard 3 01-08-2016 09:17 AM
Walking action of avatars(files are attached) SivaKartheek Vizard 1 12-15-2015 06:36 AM
walking action of avatars SivaKartheek Vizard 1 12-14-2015 10:58 PM
vizact move action andreionutz Vizard 13 11-19-2014 02:54 AM
How to make avatar's eyes to blink when speaking michelcm3 Vizard 12 01-15-2008 08:48 AM
