Old 05-03-2016, 07:59 AM
JPS JPS is offline
Registered User
Question vizconnect problems after Windows update
Hi everybody,
the new windowsUpdate (KB3147458) was installed on my pc. After that update the vizconnect and some joystick buttons does not work. Joystick is fine calibrated.
1. After the Update the vizconnect drives crazy. I mean wenn i add an Event and i try to map with the joystick, the 'clicked once' submenu disapear instantly, even if i did not pressed any joystick button to map the event.
2. They z down button witch is mapped with the leftclick mousebutton does not work in my Application anymore
3. Wenn i deinstall the windows Update (KB3147458) vizconnect and my app works fine.
Does anyone has an idea how to fix this bug?
Old 05-04-2016, 10:05 AM
Thanks, we'll look into this and update when we have more information.
Old 05-04-2016, 02:23 PM
Chris Coffin Chris Coffin is offline
Are you using an Xbox one controller? If so, we've added a specific input for the xbox one controller to vizconnect, which fixes the functional issues, and will also provide more reasonable mapping names.
Switching between input devices setup in vizconnect and not using vizconnect JB_HP_Viz Vizard 1 01-20-2015 06:19 AM
Vizard 5 Demo Launcher Problems VR_user Vizard 1 07-01-2014 02:56 PM
Vizconnect Save As Dialog Jeff Vizard 0 05-01-2014 10:45 AM
addText problems with 3 windows Ravi Vizard 1 08-25-2008 06:51 PM
Linking problems with Live Character Frank Verberne Vizard 5 06-04-2008 12:42 PM
