Old 03-30-2015, 07:33 PM
cmeans cmeans is offline
How to track Continuous Motion
I'm very new to Vizard. I'm working on a research project where I use a Kinect to track gestures. Ideally, the subject will make a gesture and as long as they maintain that gesture AND it is in motion, the avatar moves in the virtual environment.
For example, let's say want my IRL subject to make a right angle with their right arm and sweep it out from their stomach. While they move their arm in that position, the avatar runs. However, if they stop moving their arm, the avatar stops running. If they drop their arm to their side, the avatar stops running.
I have the gesture code. How do I track the continuous motion?
Old 04-01-2015, 03:59 AM
You could register a callback function with vizact.onupdate or vizact.ontimer to check the gesture state each frame or other specified time interval and then change the avatar animation. You could also create custom events for the different gestures and handle those events.
beginner, continuous motion, kinect, motion tracking, vizard
Continuous DAQ with NI USB 6008 and DAQmx mhead10 Vizard 2 09-19-2012 09:29 AM
PPT Mocap and Motion Builder Connection Problem hxphan Precision Position Tracker (PPT) 3 02-22-2011 11:01 AM
reproduce a motion 7up Vizard 1 12-10-2010 10:12 AM
an object in motion does not stay in motion? driechers Vizard 2 11-09-2010 03:51 PM
Motion Capture & CyberGloves EnvisMJ Vizard 1 10-01-2009 04:21 PM
