Old 03-20-2015, 09:34 AM
TheSwaine TheSwaine is offline
workflow from makehuman to vizard
hi there,
i am currently working with an avatar creation workflow.
You export your data from MakeHuman to 3ds Max where you build up your
biped skeleton and apply it on your model. After that you use the Material Editor to apply the skins which you have to number through. After that you are have to give it some movement via "cpy" files which you can also create on 3ds max.
All in all it works perfectly fine!
I can make it move via the states correctly and it works relatively good.
My question is, does anyone have also a problem with the skinning? every single skin i apply seems to have a bias in it. for example....my jeans are "open". my skin seems to be slightly shaken.
Does anyone also encountered this problems?
cheers
swaine
ID:	685   Click image for larger version
Normal Map Workflow for Vizard shivanangel Vizard 2 03-10-2009 07:54 PM
