Old 08-29-2014, 06:54 AM
yomomano yomomano is offline
How to get VizChild from an osg::Node
I made an extension to find a osg::Node in the osg sceneGraph using a name path (as in a/b/c) in order to speed up the lookup in a huge scene.
I want to return the found osg::Node as a VizChild. How can I do this in the extension? I don't have/need a custom node.
The only way I managed to do this is by returning the osg::Node name, and in python script calling 'parent.getChild(name)'. But when the parent is not a known VizChild, this fails.
Ex in py script I want to do this:
#sceneRoot is a VizGroup
node = myextension.findNode(sceneRoot, 'a/b/c')
#node should be a VizChild made from the underlying osg::Node with name 'c'
Thanks!
'VizChild' object has no attribute 'state' nat_bor Vizard 3 03-11-2011 11:51 PM
