Old 09-01-2014, 03:31 PM
Notch Notch is offline
Detecting collision with on-the-fly object
I have generated on-the-fly cylinders using vizshape.addCylinder(). I would like to detect collisions with a specific cylinder.
I am able to detect collisions with objects using viz.callback(viz.COLLISION_EVENT,onCollision). I can get the name of the object collided with by using the following code:
def onCollision(info):
	print('Collided with object',info.object)
Although this returns something like "Collided with object viz.VizPrimitive(9)", but I have way knowing what 'VizPrimitive(9)' is. I have several objects in the scene, and ideally would like to add names to the objects at the time they are created, so that I can then work out what I'm colliding with later on.
How do I name on-the-fly objects, and how do I then get the name of the object when a collision occurs?
Real time collision and object navigation sunil.nair Vizard 11 10-04-2013 08:10 PM
Find collision point of line and arbitrary object asdf Vizard 2 01-28-2013 10:04 AM
linked object collision pgagolf Vizard 1 04-19-2007 01:27 PM
when collision mode is on, can i "turn it off" for an individual object? Vdoug Vizard 1 09-22-2005 12:14 PM
