Old 02-07-2013, 07:03 AM
pankaj bansal pankaj bansal is offline
razor hydra...
hiii
I have a game controller joystick called 'Razor Hydra'.. I am trying to use it using the vizjoy module of vizard but its not working .. I guess may be its not supported... Can someone tell me why its not working... Its not getting any input..
I think I may have to do it using VRPN data .. That I can do... But I want to know if its possible to do work on this using only the vizjoy module....
Regards
Pankaj Bansal
Old 02-12-2013, 12:55 PM
The vizjoy module should work with any DirectInput compatible joystick device. When you say it is not working, do you mean that the vizjoy module does not detect the device?
I had a quick look at the Razer Hydra page, but could not find any technical information regarding how to interface with the device. If it uses a proprietary SDK, then Vizard does not currently support the device.
Old 09-05-2013, 11:59 AM
Feuereissen Feuereissen is offline
Razor Hydra and Vizard 4
Hi everybody --
Just found this thread and was wondering, if somebody has managed to get the Hydra up and running in Vizard yet.
Pankaj - did it eventually work out for you and if so, what did you do?
Thank you,
Daniel.
