Old 06-19-2013, 05:24 PM
javadi javadi is offline
Adjusting the centre of an object
I have a set of .dae files, each containing one object. The objects are not centred in the files. I am wondering whether there is any way to centre the objects in Vizard using programming?
More details... I want to create a grid of objects and I need to put them exactly at the nodes. I used .getPosition() method to look at the position of the object within the .dae files, but it always reports [0, 0, 0]. I used .center method as well. It doesn't make sense though, as this method is also based on the origin of the .dae file, rather the object in it. Any suggestion would be highly appreciated. Very many thanks.
Greetings
Amir
center, centre, object
AMD graphics hardware seems not to preload object sleiN13 Vizard 2 03-20-2012 07:08 AM
Making an object to appear after other object done animating jaylocco Vizard 2 07-13-2009 07:17 PM
rotate to object jargon Vizard 1 08-08-2005 01:20 PM
