Old 09-24-2012, 12:55 AM
leoaered leoaered is offline
Unhappy Shader Trouble
I'm trying to send the model view projection matrix from the CPU side into my shader, but it's not working as expected. I have two objects loaded into my scene, without any transformations: 'box.wrl' and 'ground.osgb'.
1) Sending over the projection matrix seems to mess up the order of rendering.
uniform vec4 S1, S2, S3, S4;
void main()
	gl_Position =  mat4(S1, S2, S3, S4) * gl_ModelViewMatrix * gl_Vertex;
	//gl_Position = ftransform();
When I pass in viz.MainWindow.getProjectionMatrix(), the scene looks OK, just the ground is rendered on top of the box. I don't really understand why, since if I use ftransform() or the inbuilt gl_ProjectionMatrix/gl_ModelViewProjectionMatrix the problem goes away. I also don't think there is a problem with the way I'm sending over the matrix, because I tried hardcoding the projection matrix into the vertex shader and had the same issue.
2) I can't get the view matrix to work, or I don't understand how to get it.
void main()
	gl_Position =  gl_ProjectionMatrix *  mat4(S1, S2, S3, S4) * gl_Vertex;
I tried passing viz.MainView.getMatrix() / viz.MainWindow.getMatrix() to no avail. The box doesn't show up properly. What am I missing? The model matrix should be identity because I didn't have any transforms on the objects.
*Sorry for the double post in Vizard 3.0 forum. I realized I posted on the wrong forum, and also have more useful information this time.
Vizard Headlight in Shader shivanangel Vizard 1 06-27-2012 02:19 PM
SSAO Shader Implementation FranciscoPeters Vizard 2 10-08-2011 05:19 AM
How to apply shader and render texture to an object whj Vizard 0 04-23-2010 01:23 PM
Multiple Textures for Diffuse and Specularity Shader Issue shivanangel Vizard 1 05-11-2009 11:44 AM
Specular Shader Issue shivanangel Vizard 2 05-06-2009 12:08 PM
