Old 08-28-2012, 06:59 AM
sleiN13 sleiN13 is offline
Vizard 3 sensor plugin
I'm trying to port a Vizard 4 (sensor + extension) plugin I wrote to also work with Vizard 3.
So far I got all the basic sensor stuff working, but in vizard 4 I got access to some custom python functions for the tracker. I would also like to port these to the vizard 3 plugin but I can't figure out how to add the functionality.
The sensor example code only uses the Command() function to recieve communication. The PythonPluging example does add some new python callable functions but I can't combine the two.
Is there somewhere an example on how I could do all this?
