Old 04-16-2012, 05:18 AM
torbeng torbeng is offline
<node3d>.save() position and rotation
I'm currently trying to apply some transformations (scale, position, rotation) to a model and save it to an .ive file using <node3d>.save(). However, all of these transformations are lost when I open the file.
I played around with the different modes for setting a position, e.g. setPosition(0,0,10,mode=viz.REL_LOCAL), but it does not seem to have any effect. Is there any way to save the model with these transformations applied? Thank you very much for your help in advance.
position, rotation, save, scale, transformation
limiting object rotation Philippe Vizard 5 10-07-2010 04:31 PM
Can you link the position of a tracker to the orientation of an object? michaelrepucci Vizard 1 09-19-2008 10:23 AM
getting absolute rotation tavaksai Vizard 1 08-03-2004 01:40 PM
