Old 06-23-2011, 02:08 AM
sleiN13 sleiN13 is offline
Emagin Z800
The Emagin Z800 headtracking doesn't work in Vizard 4, it produces the following error message in vizard:
emagin.dls eMagin v2.0
** ERROR: Could not connect to eMagin device. Error: 80004005
When I run the same code on the same machine with Vizard 3 it works fine. I've tested it by switching back and forth between the two versions with the same results everytime.
PS.
Is there a section where you can report bugs for Vizard 4?
eMagin Z800 problems ashmann4chins Vizard 1 03-03-2011 08:12 AM
Including eMagin DLS - viz.link? msong Vizard 1 03-11-2009 08:56 PM
emagin stereo vision quadro fx 570 smith11235 Vizard 5 08-05-2008 12:01 PM
nVisorSX vs eMagin betancourtb82 Vizard 4 09-20-2007 02:18 PM
Emagin Z800 problem michaelinTX Vizard 5 07-12-2007 05:18 AM
