Old 11-08-2011, 05:37 AM
jacky jacky is offline
texture invisible on .IVE model
Hi all,
I want to change the texture of models randomly. But I find that <node3D>.texture() didn't wrok on the .IVE model, like a sphere or a box and it worked fine on .wrl models. I built models in 3DSMAX 2010. Does somebody know the reasons? Is there something wrong with setting of the OpenSceneGraph Exporter? Thanks!
Old 11-09-2011, 02:36 PM
Hi Jacky,
The usual cause of this kind of problem is exporting a model without an initial texture. With the way the exporter currently works, any UV channel that is not being used by a texture is not included in the export.
If a model is going to be textured within Vizard, assign another texture to work as a stand-in before exporting the model.
Weird texture on .ive model viewed from Sensics HMD Zhi Vizard 11 02-25-2013 05:38 AM
The problem of adding two .ive models hengshan.li Vizard 1 08-08-2011 01:04 AM
Avatar texture swaping sleiN13 Vizard 5 06-24-2011 01:48 AM
texture .ive or .wrl jaclyn.bill Vizard 7 05-20-2011 09:19 AM
Change model alpha and memory leak hosier Vizard 2 06-25-2009 11:55 AM
