Old 09-30-2011, 04:20 AM
Veronika Veronika is offline
walking of avatar via patriot
I want to set the avatar and sensor, that the sensor is on the place, when the calibration was, in the virtual place the avatar stands too and subsequently, into which the direction the sensor is moving, so in the virtual world avatar is moving in the same direction. But my avatar is always rotated around all axis. I use patriot. can you help me with this?
thanks
Old 09-30-2011, 08:10 PM
Do you want the avatar to only move X-Z for position and yaw for orientation? If so, you'll have to pull out just those values from the tracker data and apply them to the avatar's position and orientation.
Old 10-03-2011, 01:16 AM
yes, I need only this. But how I can pull out those values from track data and apply them to the avatar?
Old 10-04-2011, 04:01 PM
Within a function that gets called every frame you can get the tracker data as lists and extract the values you want to use. Something like the following:
def updateAvatar():
	pos=tracker.getPosition()
	ori=tracker.getEuler()
	avatar.setPosition([pos[0],0,pos[2]])
	avatar.setEuler([ori[0],0,0])
vizact.onupdate(0,updateAvatar)
Old 10-05-2011, 07:06 AM
I have this code:
#set main view (x,z,y)
viz.MainView.translate(0,2,-15)
viz.clearcolor(viz.GRAY)
#Connect to Patriot sensor
polhemus = viz.add('polhemus.dle')
patriot = polhemus.addPatriot()
avatar=viz.add('male.cfg')
#Link the hand to the Patriot data
viz.link(patriot,avatar)
def updateavatar():
pos=patriot.getPosition()
ori=patriot.getEuler()
avatar.setPosition([pos[0],0,pos[0]])
vizact.onupdate(0,updateavatar)
and I want to walk with avatar and if sensor is further from calibration place, the speed of walking is more. But this code for update avatar isn't function. I whole day try to set this, but I don't know how. Can you help me with this?
Old 10-05-2011, 12:59 PM
Try removing the line where the avatar is linked to the Patriot data. That link is overriding the update function.
Old 10-07-2011, 01:33 AM
it's function thank you very much
Avatar walking + camera free look kovitch Vizard 2 08-08-2011 08:57 AM
avatar walking over a sequence of points IGoudt Vizard 1 10-16-2009 12:22 PM
avatar automatically runs animation after fading into view v-clizzin Vizard 1 10-14-2009 06:01 PM
Looking through the eyes of an avatar Frank Verberne Vizard 2 04-01-2008 06:52 AM
How to make avatar's eyes to blink when speaking michelcm3 Vizard 12 01-15-2008 09:48 AM
