Old 06-22-2011, 01:04 PM
Aweless Aweless is offline
.dae object following camera
I used sketchUp to create a level and I exported the level as a .dae file. The level loads just fine, but if I move the camera the entire loaded level moves with it. All I did was viz.add(.dae). I have no clue why a loaded .dae file would do this.
Old 06-23-2011, 11:36 AM
Does it also turn with the camera, or just move? If it's only moving, then it sounds like the scale of the model is very large. In this case try scaling it down. You can also try adding the following line of code before adding the model:
viz.setOption('viz.model.apply_collada_scale',1)
viz.add('file.dae')
This will automatically scale the collada model to meters if the model units are specified within the dae file.
Old 06-23-2011, 12:17 PM
viz.add('file.dae')
Thank you this solves my problem. It seems the scale was out of whack.
Camera distance problem CRI Vizard 0 07-28-2010 11:58 AM
rotate camera about an object dwaik Vizard 2 02-09-2010 02:06 AM
rotate to object jargon Vizard 1 08-08-2005 01:20 PM
