Old 09-27-2011, 10:55 AM
jassel41 jassel41 is offline
Check if file exists
Is there a way to check if a file exists in the current directory through code?
I don't want to access this file per say, I just want to verify that it already exists in the directory.
Jassel41
Old 09-27-2011, 10:58 AM
You can use the os.path.isfile command to check for file existence.
import os
if os.path.isfile('foo.txt'):
    print 'File exists'
Old 09-27-2011, 11:22 AM
That's perfect, thank you so much.
Closing of an imported .py file Uttama_vizard Vizard 2 05-04-2010 06:18 AM
IVEx file extenstion unrecognised. sindi Vizard 2 12-10-2009 01:20 AM
writing joystick position to a data file Saz Vizard 3 12-17-2008 05:18 AM
Read file....many issues Uttama_vizard Vizard 9 07-08-2008 02:16 PM
File Management Uttama_vizard Vizard 2 07-01-2008 09:44 AM
