Old 04-09-2011, 06:18 PM
Renato Lima Renato Lima is offline
Question Blurryness, see image
Hello friends, my textures get way too blurry when seen on an angle, any ideas as how to minimize this problem?
Ex:
Thanks!
Old 04-09-2011, 08:44 PM
Try using the <texture>.anisotropy or <node>.anisotropy commands. Anisotropic filtering is used to alleviate the exact problem you are having.
If that doesn't help, then you might need to use a higher resolution image.
Jpeg Image issue? VelvetElvis Vizard 0 03-05-2010 07:20 AM
screen image erchrastil Vizard 8 06-27-2008 12:45 PM
View an image on the Fakespace HMD roman_suvorov Vizard 16 05-23-2008 08:51 AM
Only part of tiled image vizmaster Vizard 5 09-11-2006 01:11 PM
