Old 03-31-2011, 03:29 PM
Renato Lima Renato Lima is offline
Question Can I create a box like this in Vizard?
Can I create a box just like this in vizard ? I can easily make it transparent, but I would love to have this effect on its vertices. However, I could not find a way through add.vizbox.
Ideas? Thank you very much.
Old 03-31-2011, 03:41 PM
Yeah, just create another box and set the polyMode to viz.POLY_WIRE. Here is some sample code that shows how to achieve this effect:
size = [1,1,1]
box = viz.addGroup()
box.faces = vizshape.addBox(size,splitFaces=True,cullFace=False,parent=box)
box.faces.alpha(0.5)
box.faces.color([0.77, 0.90, 0.13])
box.lines = vizshape.addBox(size,lighting=False,cullFace=False,parent=box)
box.lines.polyMode(viz.POLY_WIRE)
box.lines.lineWidth(6)
box.lines.color([0.24, 0.42, 0])
.3DS importing in Vizard and 3D Studio jde Vizard 1 08-28-2009 04:14 PM
