Old 12-20-2010, 03:54 AM
psykoko psykoko is offline
continue loading...
HI.
i am received udp signal from matalb successfuly. throught following coding
import socket
import struct
UDP_IP="localhost"
UDP_PORT=8020
sock = socket.socket( socket.AF_INET, # Internet
socket.SOCK_DGRAM ) # UDP
sock.bind( (UDP_IP,UDP_PORT) )
while True:
      data, addr = sock.recvfrom( 1024 ) # buffer size is 1024 bytes
      udp = struct.unpack(">d", data)[0]
      right = open('c:\ownership\Hand2.txt', 'a+')
      right.write(str(udp)+'n')
True.close()
but i have any problem.
this code seems to continue loading screen.
how can solve this problem??
Old 12-20-2010, 11:06 AM
Try using a director function to read in your network data. They are documented in the Vizard help and are useful for performing IO operations that would otherwise halt rendering.
Old 12-20-2010, 08:05 PM
hi jeff,
i have solved my problem, thankyou. i did coding as follows
import socket
import struct
import vizmat
import vizinfo
viz.go(viz.PROMPT | viz.STEREO)
UDP_IP="localhost"
UDP_PORT=8000
#Add an avatar to the scene
female = viz.add('vcc_female.cfg')
viz.clearcolor(0.5,0.5,1)
female.setPosition([-0.08,0,0.8])
female.setEuler([0,0,0])
female.scale(1.4,1,1)
#speed
MOVE_SPEED = 10
TURN_SPEED = 50
#view point
view = viz.MainView
#Get a handle to the Arm bone
Forearm = female.getBone('Bip01 R Forearm')
Forearm.lock()
Forearm.setEuler(0, -5, 0)
UpperArm = female.getBone('Bip01 R UpperArm')
UpperArm.lock()
UpperArm.setEuler(0, -30, -80)
Hand = female.getBone('Bip01 R Hand')
Hand.lock()
Head = female.getBone('Bip01 Head')
Head.lock()
Head.setPosition(-100,0,0)
Neck = female.getBone('Bip01 Neck')
Neck.lock()
Neck.setEuler(0,0,-15)
def example1():
	while True:
		print udp
		right = open('c:\\ownership\\test.txt', 'a+')
		right.write(str(udp)+'\n')
		if 0 < udp:
			a = Forearm.getEuler()
			A = a[2]
			n = max(A -0.5,-90)
			N = A + 90
			Forearm.setEuler(0,0,n)
			if n == -90:
				Forearm.setEuler([0,0,N])
		else :
			b = Forearm.getEuler()
			B = b[2]
			n2 = min(B +0.2,0)
			Forearm.setEuler(0,0,n2)
viz.director(example1)
but another problem is induced.
when i load my avartar, udp signal is losed.
but when i down(minimize "_") window seeing avartar, udp signal is receive perfectly,
i want to receive udp singal in window loaded avartar.
how can i?
Old 12-21-2010, 05:15 PM
Try using the director function for just reading in the network data. To update the avatar register a callback function with vizact.ontimer or vizact.onupdate.
Old 12-23-2010, 07:38 PM
Hi. i did modify my code, but i don't work correctly.
please modify my code
import vizmat
import vizinfo
import socket
import struct
Forearm.lock()
UpperArm.lock()
Hand.lock()
Head.lock()
Neck.lock()
UDP_IP="localhost"
UDP_PORT=8000
udp = 0
def example1():
	global udp
	while True:
	True.close()
def update():
	print udp
	right = open('c:\\ownership\\test4.txt', 'a+')
	if 0 < udp:
		A = a[2]
		n = max(A -0.5,-90)
		N = A + 90
		if n == -90:
	else :
		B = b[2]
		n2 = min(B +0.2,0)
vizact.ontimer(0,update)
Old 12-28-2010, 01:52 AM
Hi. worldviz.
is this not solved my problem??
i want to your help.
i don't solved my problem
Loading OSG models and orientation Joran Vizard 4 06-18-2009 05:43 AM
intersense with 5DT glove sjp Vizard 2 04-06-2009 07:22 AM
Problems loading WRL file DrunkenBrit Vizard 2 01-29-2009 12:58 AM
Loading .3ds-Files without interrupting Program flow Stefan Vizard 10 06-08-2005 04:44 PM
Script loading problem JRichizzle Vizard 1 03-12-2004 10:03 AM
