Old 08-26-2010, 02:19 AM
shahramy shahramy is offline
Smile mouse pointer
hi
I changed mouse pointer as duckcourt example. I need to use viz.pick but I can not. is there way to solve this problem?
thank you all
Old 08-31-2010, 01:52 PM
Can you post some example code that's shows your problem?
Old 09-04-2010, 03:27 AM
I meant I want to change cursor shape. if I link a object to mouse pointer, when I use viz.pick, that object has been returned.
Old 09-07-2010, 03:22 PM
The following code links an object to the mouse position and correctly returns the picked object.
viz.link( viz.Mouse , viz.addTexQuad(viz.SCREEN,texture=viz.add('crosshair.png')) )
viz.mouse(viz.OFF)
viz.mouse.setVisible(viz.OFF)
court = viz.add('court.ive')
male = viz.add('vcc_male.cfg',pos=[-1,0,5],euler=[180,0,0])
male.state(1)
female = viz.add('vcc_female.cfg',pos=[1,0,5],euler=[180,0,0])
female.state(1)
def getPicked():
	object = viz.pick()
	if object == male:
		print 'male'
	elif object == female:
		print 'female'
	elif object == court:
		print 'court'
vizact.onmousedown(viz.MOUSEBUTTON_LEFT,getPicked)
Warning mouse() -> Set mouse() of window johannes2 Vizard 1 08-19-2010 03:11 PM
how to remove velocity when mouse is disabled? jvacare1 Vizard 2 02-18-2010 11:25 AM
Navigating an avatar using mouse position(2D) in 3D environment james007 Vizard 1 10-16-2009 12:29 PM
Laser Pointer Question (Again) Elittdogg Vizard 5 09-08-2009 01:02 PM
how to make the mouse pointer pain... yak Vizard 0 05-30-2009 08:05 PM
