Old 09-20-2012, 06:36 PM
mhtong mhtong is offline
CompositeShape proximity sensor
I'm designing an environment where it's important to track whether or not the subject is on or off a particular path. The path is fairly simple, composed of a QUAD_STRIP. However, the proximity sensors just provide Box and Sphere.
I'm generally ok with the amount of slop introduced by rounding up each quad in the quad strip to be rectangular and a Box. Ideally, it seems like a CompositeShape sensor composed of a Box for each quad in the strip should work well. But the Box shape assumes axis alignment. Sensors attach fine to their parent's coordinate system, and then rotate accordingly - but Boxes themselves don't have parents, and a CompositeShape seems to therefore only be able to be made of boxes aligned to the same coordinate system.
Suggestions? Am I missing something?
Unusual tracker sensor setup with Vizard Zhi Vizard 2 06-12-2012 10:52 AM
sensor or not sensor? nige777 Vizard 0 03-29-2011 05:03 AM
wiimote and sensor bar masaki Vizard 1 03-06-2008 04:07 PM
Multiple Copies of same sensor plugin RedSpikeyThing Plug-in development 2 02-12-2008 03:10 PM
