Old 04-21-2010, 08:54 AM
a_kiefer a_kiefer is offline
Importing material/objects from 3DS Max to Vizard
I'm attempting to import a wall with refractory material I created in 3DS Max. I am exporting the file as a .3ds file and when I try to pull it into Vizard the wall only shows up as a white object (the wall was created with a white color) with no refractory material. Can't figure out why this is happening. Do I need to export the file in a different format?
.3DS importing in Vizard and 3D Studio jde Vizard 1 08-28-2009 04:14 PM
Vizard won't run wouters Vizard 5 02-05-2008 12:12 PM
