Old 03-22-2010, 05:41 PM
Darkmax Darkmax is offline
how use i-Glasses HMD in vizard?
i have hmd i-Glasses with serial connection but i cant use it with the hardware headtracking code, some one know how to use it?
which dll i have to load to make it work?
Old 03-23-2010, 02:54 PM
As far as I know the i-Glasses model for the PC does not have a built-in tracking device. I'm not sure what you mean by getting it to work with the hardware headtracking code.
Old 03-23-2010, 06:18 PM
mm my virtual i\o from i-glasses has a tracker in the back part of the HMD.
it has a three degree of freedom orientation tracker.
here is a link of the picture of the hmd that i have.
http://graphics.stanford.edu/infrast.../iglasses.html
http://www.xolmatic.com/xprojects/i-glasses.htm
i know that the tracker works because i tried with other software that we have in our lab
Old 03-24-2010, 02:51 PM
some where i read that vizard supports hmd i-glasses but i don't know how to make my head tracker make it work.
i tried to read from serial port the information and its working but it throws me an array of hexa-decimal numbers but if vizard has a plugin like 5dt gloves it will be really thankful but i was searching in the worldviz folder and i couldn't fint it
Old 03-24-2010, 05:49 PM
We do not have a plug-in for that tracker.
Old 03-26-2010, 10:38 AM
Oh well, i have another question, if i have vizard lite, is possible to do the plug-in for the head tracker or i need vizard developer?
.3DS importing in Vizard and 3D Studio jde Vizard 1 08-28-2009 04:14 PM
Problems implementing Vizard in a CAVE with Shutter Glasses shivanangel Vizard 7 05-20-2009 12:47 PM
