Old 02-09-2010, 11:05 AM
aquCHAOS aquCHAOS is offline
Question about 3Ds MAX to Cal3D to Vizard
I'm trying to export 3Ds MAX characters and animations to Vizard, not very successful...
I encountered following questions:
1. The materials aren't exported well. I use Unwarp UVW in 3Ds MAX, can it be exported with Cal3D exporter?
2. The animation and the mesh are not good coordinated, the mesh is extremely stretched, see pictures below...
3. If the character has a large amount of polygons, 3Ds MAX will crash when exporting the Cal3D mesh file...
Anyone can help?
ID:	356   Click image for larger version
ID:	357   Click image for larger version
Old 02-12-2010, 12:13 PM
Hi aquCHAOS.
1. What format are you using for the textures? Have you placed them in the same directy as the exported avatar?
2. Under normal conditions, the problems you are seeing only happen when a mesh is exported onto a different skeleton than the one it was skinned to in max. If you'd like, I can take a look at the model.
3. So far, the most complex avatar we have exported was made up of 30,000 triangles, though this is much more than generally needed in most cases. This type of crash usually occurs when running out of RAM while exporting. As this sort of thing usually goes, the way to fix it is to reduce ram usage by closing all other open programs, buy more ram, increase your virtual memory allocation. Depending on your version of windows, it may also be useful to look into using the 3gb switch.
Question about virtualizing Vizard JMOwens Vizard 5 07-24-2009 11:11 AM
Stereoscopic Vizard Question mikestatic Vizard 7 03-20-2006 02:36 PM
some question on vizard sled Vizard 3 06-23-2003 12:22 PM
