Old 08-10-2009, 07:12 PM
GiudiceLab GiudiceLab is offline
Angry vizsonic error, script fails to run
I am trying to tinker with ambisonic sound using the vizsonic library. I'm getting this error:
vizsonic.py: Remote file C:\Program Files\WorldViz\Vizard30\resources\quack.wav does not exist, will copy it over
File "ambiSound.py", line 16, in ?
sound = model.playsound('quack.wav',viz.LOOP, volume=1.0, directionality=1.0)
File "C:\Program Files\WorldViz\Vizard30\python\vizsonic.py", line 98, in _node_playsound
shutil.copy2(fullpath, networkpath)
File "C:\Program Files\WorldViz\Vizard30\bin\lib\shutil.py", line 92, in copy2
copyfile(src, dst)
File "C:\Program Files\WorldViz\Vizard30\bin\lib\shutil.py", line 48, in copyfile
fdst = open(dst, 'wb')
IOError: [Errno 2] No such file or directory: '\\\\soundmac\\worldviz\\Desktop\\sound-system\\sounds/cache/ba750d308d7e6ab17ab88e31a5bcd4ba'
Despite that it says quack.wav does not exist, it does, but I think the real issue is the missing directory at the bottom of the error message. Are there dependencies for vizsonic? Anyone know how to fix this? Is it fixable?
Old 08-10-2009, 07:45 PM
Read the instructions thoroughly first
Ah, well, it seems I ran the demo before I read the entirety of the page. So can anyone explain this for me? Isn't a Mac mini a little server box?
WorldViz supplies a mac mini which is used as a controller and processor for the sound files being played by the vizard script. In order to allow the mac mini to play the sound files in the vizard script the mac mini must be network accessible and mapped to a drive letter (Z by default). When a script is started for the first time the ambisonics code will then sync the files in the user's local "sound" folder with the files on the mac mini, only copying files if they are new or newer than existing files on the mac mini.
I tried mapping \\soundmac\worldviz\Desktop\sound-system\sounds and \\soundmac\Users\worldviz\Desktop\sound-system\sounds, but no joy on either of those, so I guess I've no idea.
Virtual Environments and Multimodal Interaction (VEMI) Lab
This time, it should work...
Old 08-12-2009, 11:12 AM
wayne wayne is offline
Hi there,
If you go to Windows explorer, and type in \\soundmac\worldviz and then hit enter, does it give you an error message or ask for a username/password?
regards,
Wayne
Old 08-12-2009, 11:42 AM
One more thing I just realized, in order to use ambisonics sound, you need to have purchased the hardware from us (which includes a Mac Mini) that is necessary to generate the sound effects: http://www.worldviz.com/products/peripherals/sound.html - it is not possible to use ambisonics with the sound card built into a PC. You can still do 3D sound, but it is not ambisonic and it is limited to what your sound card is capable of.
regards,
Wayne
Old 08-14-2009, 08:00 AM
Oh, I see. Never mind then, thanks!
Installation fails for 3ds max 2008 atuin Vizard 5 09-13-2008 10:22 AM
How to tell when adding a plugin fails Jerry Vizard 1 07-06-2006 09:21 AM
