Old 09-09-2009, 04:45 AM
krimble krimble is offline
screenshots using a loop
Hi all,
can somebody help me? I have troubles with my program.
I'm busy writing a small script which is basically a loop where an object rotates in after the rotation it has to make a screenshot of it and store it on the disk with the objects name and rotation degree.
The loop works perfectly it prints out what it has to save on the disk but it doesn't save (well it saves only the last screenshot).
Do I have to approach this differently?
Thanks for your help!
viz.clearcolor(.4,.4,.4)
view.translate(12.416062355041504, 4.3263897895812988, 0)
view.rotate(-90,0,0)
s = viz.add(r"scissors.wrl")
co = viz.add(r"canopener.ive")
c1 = viz.add(r"cubes_01.wrl")
c2 = viz.add(r"cubes_02.wrl")
c3 = viz.add(r"cubes_03.wrl")
objects = [s,co,c1,c2,c3]
objectStrings = ["scissors","canOpener","cubes01","cubes02","cubes03"]
for i in objects :
	i.visible(0)
degreesY = [0,60,120,180,240,300]
degreesZ = [0,60,300]
degreesX = [0,180]
for obj in objects :
	if obj == s :
		object = objectStrings[0]
	elif obj == co :
		object = objectStrings[1]
	elif obj == c1 :
		object = objectStrings[2]
	elif obj == c2 :
		object = objectStrings[3]
	elif obj == c3 :
		object = objectStrings[4]
	obj.visible(1)
	for degree in range(0, len(degreesX)) :
		for i in range(0, len(degreesZ)) :
			for j in range(0, len(degreesY)) :
				obj.rotate(degreesX[degree], degreesY[j], degreesZ[i])
				viz.window.screenCapture('pictures\\' + object + '_' + str(degreesX[degree]) + '_' + str(degreesY[j]) + '_' + str(degreesZ[i]) + '.bmp')
				print "Created: " + object + "_" + str(degreesX[degree]) + "_" + str(degreesY[j]) + "_" + str(degreesZ[i]) + ".bmp"
Stop for... loop Johannes Vizard 20 04-01-2014 02:53 AM
Creating a loop to switch between menu pages RodRSpv Vizard 1 03-02-2009 03:19 PM
For Loop in Callbacks? DrunkenBrit Vizard 2 02-19-2009 01:26 AM
screenshots vadrian Vizard 1 04-25-2005 07:17 AM
for loop concatenation for 300 billboarding trees eugcc Vizard 4 04-22-2004 01:46 AM
