Old 05-27-2009, 01:54 AM
Joran Joran is offline
Send a message via Yahoo to Joran
Question How to remove a modifier
After running this piece of code:
toon = viz.add('toon.dlm')
ball = viz.add('ball.wrl')
ball.modify(toon)
How do you remove the toon modifier from the ball?
Greetings, Joran.
Old 05-27-2009, 12:53 PM
You can apply the toon modifier to a group node and parent/unparent the ball from the group node to toggle toon shading. Here is some sample code:
#Create group node for rendering in toon mode
toonGroup = viz.addGroup()
toonGroup.modify(toon)
#Create ball underneath toon node
ball = viz.add('ball.wrl',parent=toonGroup,pos=(0,1,5))
#Unparent ball from toon node when spacebar pressed
vizact.onkeydown(' ',ball.parent,viz.WORLD)
Remove the credits on the run screen Saz Vizard 1 11-21-2008 09:01 AM
How to access scene information in a C++ modifier m7ossny Plug-in development 1 03-23-2007 11:02 AM
collission and scaling of objects Johannes Vizard 28 02-08-2005 10:08 AM
