Old 01-28-2009, 05:52 AM
DrunkenBrit DrunkenBrit is offline
Problems loading WRL file
I've usually had no problems exporting a scene from max to VRML format before and loading it in Vizard, but this time when attempting to load this one file I get the following error:
Loading File: all_blgds.WRL
** Error: Failed to load all_blgds.WRL at line 291060
--> geometry USE Block:Layer_Window_Frames01-FACES
--> Layer_Window_Frames01-FACES
** ERROR: Failed to load 'all_blgds.WRL'
:** Load Time: 16.05 seconds
I'm no expert in max but just about get by so i'm not really aware of what this person (I didn't create the max scene) may need to do inside of max so this 'Layer_Window..etc' will be removed if it can, or what I can do in Vizard (if anything) so the file loads.
Has anyone come across/had any similar problems before? Any ideas how to solve this please?
Thanks!
Read file....many issues Uttama_vizard Vizard 9 07-08-2008 02:16 PM
File Management Uttama_vizard Vizard 2 07-01-2008 09:44 AM
problems with webcam plug-in v-clizzin Plug-in development 2 01-25-2008 03:06 PM
Problems loading dls file vnacooper Plug-in development 1 03-05-2007 09:26 AM
