Old 10-25-2008, 09:35 PM
znchb znchb is offline
How to wirte words on a BillBoard?
Hi, Is there any tutorial to show me how to wirte words on a BillBoard & the words can be changed.
such as, when we click the keyboard, it will be changed to some other words that we already prepared.
Old 10-26-2008, 06:32 PM
attached picture; Attach words directly
I just know hot to attach a picture that contains words to a 'BillBoard' ,
Eg.
self.billboard2 = viz.add('c:\\VirtualWorlds\\table\\billboard.3DS')
self.slide = viz.add('c:\\VirtualWorlds\\table\\slide2.jpg')#.j pg contain words
self.billboard2.texture(self.slide)
but not show words on 'BillBoard' directly, Is there some one help me and give me an simple example for attaching words directly?
Thanks a lot.
Old 10-26-2008, 07:36 PM
You can make a text3d object a child of a texture quad. Here, the text object is slighly offset the quad in the z direction so it can be seen clearly.
Press the spacebar to change the message
# Create surface to wrap the texture on
quad = viz.addTexQuad()
quad.setPosition([0, 1.5, 3]) #put quad in view
# Wrap white texture on quad
quad.texture(viz.WHITE)
#create text object and make it a child of the texture quad
text = viz.addText( 'message', quad )
text.setScale(.1,.1,.1)
text.alignment(viz.TEXT_CENTER_CENTER)
text.color(viz.BLACK)
text.setPosition(0,0,-.01)
#press space bar to change message
vizact.onkeydown(' ', text.message, "new message")
Old 10-26-2008, 10:13 PM
Whether we can do like this? see the & the attached files
#some problems exist. if I use quad = viz.addTexQuad(), then I can not add #the 'billboard' to the scene. how to figure out this? Appreciate
####### Create surface to wrap the texture on
#quad = viz.addTexQuad()
#quad.setPosition([0, 1.5, 3]) #put quad in view
#quad.texture(viz.WHITE)
########create text object and make it a child of the texture quad
#text = viz.addText( 'message', quad )
#text.setScale(.1,.1,.1)
#text.alignment(viz.TEXT_CENTER_CENTER)
#text.color(viz.BLACK)
#text.setPosition(0,0,-.01)
#####press space bar to change message
#vizact.onkeydown(' ', text.message, "new message")
#####Whether we can do like this: ???
main = viz.add('c:\\VirtualWorlds\\table\\poolTableScene. 3DS') # the main scene
billboard = main.getChild('billboards') # object, named 'billboards', component of 'poolTableScene.3DS'
#quad = billboard.addTexQuad()
text = viz.addText('message', quad)
text.setScale(0.2,0.2,0.2)
Old 10-26-2008, 10:27 PM
the attachment file
the scene file
Old 10-27-2008, 10:50 AM
You can make the text3d object a child of the billboard.
billboard = viz.add('billboard.3ds', pos = [0,0,5])
#create text object and make it a child of the billboard
text = viz.addText( 'message', billboard )
text.setPosition(0,1.7,-.05)
Depending on what you want to do with this billboard it might be better to create textures with different text in them and swap the textures on the billboard
By the way, we recommend exporting 3ds models into Vizards native file format (.ive/.osg). It supports baked lighting and other advanced features.
You can download the exporter for Max from our downloads page.
