Old 10-12-2008, 09:38 PM
vjesse vjesse is offline
Max system latency for HMD?
I am trying to determine the maximum system latency for our system that implements Vizard 3.0 software. The following are the specifications:
The HMD is an nVisor SX with dual 1280 horizontal by 1024 vertical pixel resolution panels. The display presents a visual field subtending approximately 50 degrees horizontally by 38 degrees vertically. Stereoscopic images are rendered by a 1900 MHz Pentium computer with an NVIDIA GeForce 6600 graphics card and updated at an average frame rate of 60 Hz.
Head movements are tracked by a three-axis orientation sensing system (Intersense IS250 with an update rate of 150 Hz) and used to continuously update the simulated viewpoint. The position of the participant along the X, Y, and Z planes was tracked via an optical tracking system (WorldViz PPT with an update rate of 60 Hz).
Thanks for any feedback you may have!
Jesse
Printing of System Time Uttama_vizard Precision Position Tracker (PPT) 2 09-19-2007 02:38 PM
Patriot Polhemus System Vinicius Lima Vizard 5 07-25-2007 09:51 AM
ImmersaDesk system tracking kgarr Vizard 10 09-14-2006 11:17 AM
Particle System... again... k_iwan Vizard 2 05-09-2006 12:42 AM
accessing system speaker noise pkhoosh Vizard 2 01-25-2006 10:22 AM
