Thread Tools Rating: Thread Rating: 6 votes, 5.00 average. Display Modes
Old 05-13-2008, 06:06 AM
Collision of an avatar with a quad
Hi all,
I'm having some problems with a task I'm making. I want to do something when an avatar touches a texquad. Therefore I created the texquad, added a collidebox around it and tested the situation. If I let the avatar touch the texquad in the beginning, something happens, but if I move the texquad 50 cm in front of the avatar and I let the avatar touch the texquad later, nothing happens. My code:
#import vizmocap
import random
#viz.go( viz.HMD | viz.FULLSCREEN | viz.STEREO )
viz.phys.enable()
environment = viz.add('gallery.ive')
quad = viz.addTexQuad()
#quad.setPosition(0,1.5,.5) #doesn't work
quad.setPosition(0,1.5,.1) #does work (once)
quad.scale(.25, .25, .25)
quad.collideBox()
quad.color(255,255,255)
quad.enable(viz.COLLIDE_NOTIFY)#object 1 for collision
quad.disable( viz.DYNAMICS )
avatar = viz.add('vcc_female.cfg')
avatar.collideMesh() #object 2 for collision
avatar.disable( viz.DYNAMICS )
#vizmocap.LiveCharacter('192.168.2.103',8050,model=avatar)
viz.MainView.translate(0,1.80,-2)
def onCollide(e):#e.obj1 == quad & e.obj2 == avatar
	if e.obj1.getColor() == [255,255,255]:
		print "white"
		e.obj1.color(viz.GREEN)
		print "green"
viz.callback( viz.COLLIDE_BEGIN_EVENT, onCollide )
I use the LiveCharacter plugin to move the avatar, but that shouldn't be the problem (I think). What I want is that the callbackfunction is activated every time the avatar collides with the collidebox around the texquad. I.e. green should be printed the second time the texquad is touched. Can somebody help me?
Looking through the eyes of an avatar Frank Verberne Vizard 2 04-01-2008 06:52 AM
How to make avatar's eyes to blink when speaking michelcm3 Vizard 12 01-15-2008 09:48 AM
avatar neck too short aa-chris Vizard 2 10-16-2007 10:28 AM
Avatars in an array and link/unlink betancourtb82 Vizard 7 09-05-2006 05:06 PM
avatar animations vduckie Vizard 12 02-27-2006 02:32 PM
