Old 09-18-2006, 02:49 PM
brystewa brystewa is offline
Matlab and Vizard
I am new to Vizard and am looking to use matlab to communicate with Vizard. I have been using pymat with python 2.2 with no trouble. I understand that Vizard has went to Python 2.4. I have found nothing about pymat with Python 2.4. The closest thing I have done is put pymat.pyd in the VIZARD_PATH\bin and try to import pymat. I get
ImportError: Module use of python22.dll conflicts with this version of Python
This suggest to me that if I had the older version of Vizard, that is the one that used Python 2.2, I would be able to use pymat.
I have also tried using the registerVizardwithpython.zip and I get
*** Unable to register!
*** You probably have another Python installation!
** Load Time: 0.02 seconds
So I unistalled Everything that had to do with python (Vizard, Python22) and then I went to my registry and deleted anything that had .py or python. And I still get the same problem.
Anyone know how I can get the Vizard with Pythong 2.2 or any other suggestion would be great.
Bryan
Old 09-18-2006, 03:11 PM
Depending on how you are using matlab, you could try and do it all in Vizard with the Matplotlib python libriary. Check out this post:
http://www.worldviz.com/forum/showth...=2869#post2869
You could also try recompiling pyMat with Python2.4's source.
