Old 08-30-2021, 09:29 AM
Suppress Vizard Cluster Client from Being Viewed On Startup
I was wondering if it is possible to add a parameter or setting someplace to suppress the Cluster Client Window from being visible on startup?
I added a shortcut to the client on our multi-screen system so that it auto-starts when the computer boots.
However, this causes the window to pop up in the middle of the screen.
Is there a flag to suppress or minimize the window I can add to the shortcut?
I am using WorldViz Vizard 5 (64-bit) on Windows 10.
Old 09-01-2021, 10:10 AM
sado_rabaudi sado_rabaudi is offline
I don't see anything in the global Vizard options to suppress the Cluster Client window. Likely it's not a feature that is no far needed. We'll put it on a list of possible Vizard updates.
https://docs.worldviz.com/vizard/lat...n_settings.htm
Best,
Sado
Old 09-22-2022, 11:35 AM
apenngrace apenngrace is offline
Yes, I found a solution for that. I'm assuming that you placed a shortcut to the Vizard Cluster Client in your startup folder. Find that shortcut, right click it, select properties. In the properties look for the Run property. Change that to Minimized.
I found that in this article.
Four Wall Cave using two client cluster JB_HP_Viz Vizard 3 05-13-2016 04:26 AM
Mouse events from a cluster client victorqx Vizard 5 08-15-2012 12:43 AM
Vizard cluster with director calls victorqx Vizard 2 08-06-2012 01:24 AM
just downloaded Vizard Lite - crashes upon startup... bernie Vizard 6 11-23-2008 10:56 AM
